vasakpal
1 month agoMAX10 RSU upgrade succeeds, but device boots Factory image instead of Application
I’m using Intel MAX10 Remote System Upgrade (RSU) with:
- CFM0 = Factory
- CFM1 = Application
The firmware‑triggered RSU upgrade completes successfully, but after reconfiguration the device boots back into the Factory image instead of the Application image.
Below is the design setup:
- RSU IP instantiated and connected over SPI
- Avalon‑MM master interface of RSU IP is exported to user logic
- onchip_flash data interface is also exported and visible in the top level
- Firmware performs erase/write/verify through the exported Avalon‑MM interface
- Autoboot decision is based on a bit stored in UFM, read at startup
No external power cycle occurs during RSU (warm reconfiguration).
Below are the observations:
- RSU programming via firmware completes without errors
- MAX10 reconfigures after RSU
- Cold boot works correctly
- Programming the App image via JTAG works
- Issue occurs only after warm RSU (no power cycle)
Autoboot selection is controlled via a bit stored in UFM. For this I have exported the AV-MM
I have the below questions:
- Is it expected that RSU does not automatically re‑enter autoboot logic?
- After warm RSU, must user RTL explicitly regenerate a boot / autoboot event?
- Are there recommended MAX10 reference patterns for autoboot handling after RSU?
Thanks for any guidance or references.
