10 years agomax10 on chip flash read/write in nios
hi everone, for two weeks i stuck in the max10 on chip flash read/write in nios.
in my project, it has a nios system and the clk frequency is 100mHz. i want to use the internal configuration mode of max10(single compressed image with memory initialization), as well as read/write the chip flash UFM in nios. i can read the UFM, but i can not write to it. the following is my code, i run it in debug mode flash_status_reg1=IORD_32DIRECT(ONCHIP_FLASH_0_CSR_BASE,0x0); // read the flash_status_reg, the result is 0xfffffc04, flash_control_reg1=IORD_32DIRECT(ONCHIP_FLASH_0_CSR_BASE,0x4); // read the flash_control_reg, the result is 0x3fffffff, flash_data_reg1=IORD_32DIRECT(ONCHIP_FLASH_0_DATA_BASE,0x0); // read the first 32 bit of UFM1,the result is 0x0, while(1) { flash_status_reg1=IORD_32DIRECT(ONCHIP_FLASH_0_CSR_BASE,0x0);//read the flash_status_reg, the result is 0xfffffc04, it means read success flash_status_reg1=flash_status_reg1&0x4; if (flash_status_reg1== 0x4) break; // write success } // write to UFM1 IOWR_32DIRECT(ONCHIP_FLASH_0_CSR_BASE,0x4,0xff7fffff);// disable the write protection of UFM1 flash_control_reg1=IORD_32DIRECT(ONCHIP_FLASH_0_CSR_BASE,0x4);// read the flash_control_reg, the result is 0x3f7fffff, IOWR_32DIRECT(ONCHIP_FLASH_0_DATA_BASE,0x0,0x12345678);// write to the first 32 bit of UFM1, then the debug stuck in here can someone gives me some help? i have found the reference desin for how to use the UFM in quartus without nios; i also have found the reference desin for how to use the onchip internal configuration mode of max10 in nios system; but i have not found a reference desin use nios, and the UFM thanks!
