14 years agoMaking a counter from 50MHz Clock?
Hi, I know this might be a really silly question but I can't seem to get the theory down into HDL: I want to make a 3579545Hz clock from a 50MHz clock input: i know that --- Quote Start...
14 years agoSorry,
Work and school got a bit overwhelming... I'm able to spend a few days working on some VHDL now :) I will try to comment your code to confirm i understand it. --- Quote Start ---
process(clk)
variable count : unsigned(26 downto 0) := (others => '0'); //why others => '0'?
begin
if rising_edge(clk) then
if count > 50000000-1 then
count := count - 50000000; //set count to 0
else
count := count + 3579545; //very clever "modulo" does it really work as such?
end if;
my_clk <= std_logic(count(25)); //passes bit 25 and uses as a clock signal
end if;
end process;
--- Quote End --- thanks for your help!!
