Vigneswaran
1 month agoLVDS support on Agilex 7
HI, Im working on INTEL AGILEX 7 F-SERIES X2 F-TILE FPGA. Please clear my doubt
In True differential signalling of LVDS , it is mentioned as differential signal with common mode voltage of 1.4 you can have only 100mV swing. So you are limiting it to only 1.5V including the swing. if i have a secondary device and it has common mode voltage of 1.375V and swing can be 200mV.So , my full swing voltage is going to be 1.575V. Will this signal , can be captured by FPGA GPIO pin or not? Whether it will damage ,my pins in FPGA?
