sbj's avatar
sbj
1 month ago
GPIO default state before FPGA configuration (weak pull-up vs. pull-down)
Between power-on and FPGA configuration, the GPIO pins are in a tristate condition with a weak pull-up enabled. As a result, the device’s digital outputs are initially driven HIGH and only switch to their intended state (LOW) after the FPGA configuration is complete.
This behavior is causing problems for downstream signal evaluation.
Questions:
  • Is it possible to modify this default behavior of the GPIO pins before configuration?
  • Specifically, can a pull-down (instead of a weak pull-up) be configured or enforced during the pre-configuration phase?
Any guidance or recommended solutions would be appreciated.
  • Hello,
    The default pre-configuration weak pullup cannot be changed to a weak pulldown. This is because the hardware defaults are fixed and cannot be altered via software or fuse before configuration.
    If a low state is required prior to configuration, it is recommended to use external pulldown resistors to override the internal weak pullup.
    regards,
    Farabi
    • sbj's avatar
      sbj
      All good! Thank you very much for your support
  • Farabi's avatar
    Farabi
    regards,
    Farabi
