FabriceNs's avatar
FabriceNs
29 days ago
FPGA issue on electronic board
The FPGA is visible via the JTAG probe, and we can program firmware. It seems to run correctly. This is a good point.
At this stage, we have tried to implement I2C accesses to configure a clock component on the electronic board and unfortunately, we did not succeed.
We observed a strange behaviour on I2C pads.
I2C pads are bi-directional pads and implemented in open drain mode :
to output a ‘0’ value, pad is configured as output and driven to ‘0’ by internal logic of the FPGA.
to output a ‘1’ value, pad is configured as input and signal is driven to ‘1’ by an external pull-up resistor.
As the external clock component is not configured (and does not output clocks by default) we use for this firmware
As any bi-directional pad, whatever is the pad direction configuration, electrical signal on external IO should always be replicated on <dout>. But it is not the case on one of the banks of our FPGA.
To simplify the tests, we have implemented a smaller testcase firmware :
2x bi-directional IOs (SDA and SCL)
A weak pull-up (in IO pad) on each of these two IOs (to emulate I2C external pull-up)
We have chosen IO which are not routed on the electronic board (NC balls)
We performed the test on two different banks (6B and 6D). Both banks are HVIO banks are powered with 1V8.
The bi-directional pads behave as expected : io pad signals (driven by <scl_t> and <sda_t>) are replicated on <dout> pins of bidir primitives (<scl_i> and <sda_i>).
The bi-directional pads do not work. <dout> pins of bidir primitives (<scl_i> and <sda_i>) are tied to ‘1’.
The two designs are 100% identical excepted the pin locations !!
We tried to output a clock signal on some IOs pads of the bank 6D configured as output (pins without pull-up neither in pad or on electronic board) and we can observe a clock waveform of 1V8 amplitude on the scope, which means the bank 6D is powered with 1V8.
Unfortunately, we currently have only one functional FPGA board. Others should arrive by the end of the week.
We are using Quartus Prime Pro 25.3.1 (patch 1.02)
What could be the reasons explaining this difference in behaviour between two identical banks ? Could it be :
a Quartus tool bug ?
a silicium issue ?
a bank power supply problem ?
  • Farabi's avatar
    Farabi
    In your setup, do you have external pullups for the I2C signals?
    regards,
    Farabi
    • FabriceNs's avatar
      FabriceNs
      Hi Farabi,
      No there are n pullup for the I2C signal.
      Do you know if this is a known issue?
      Fabrice
  • Farabi's avatar
    Farabi
    I need more details on your setup in order to help you.
    1- Are you using I2C on HPS?
    2- What are you trying to achieve?
    regards,
    Farabi
      FabriceNs
      Hi Farabi,
      It's OK for sharing you more details
      No, I am using I2C without HPS
      Trying to implement I2C accesses to configure a clock component on the electronic board.
      The test has been performed on two different banks (6B and 6D).
      Find attached the screenshot which highlight the issue
      SignalTap on bank 6B which works correctly
      SignalTap on bank 6D which does not work
      Fabrice
      • Farabi's avatar
        Farabi
        Are you able to pullup the I2C signals and see if this can fix the issue?
        There are internal weak pullup for the IOs but it might be not enough for longer trace I2C signals.
        regards,
        Farabi
