niliev's avatar
niliev
28 days ago
Cyclone-V SCFIFO - adding ECC to M10K/MLAB/Auto memory
I am working with a Cyclone-V  5CSXFC6C6U2317  FPGA and using the MegaWizard's IP FIFO SCFIFO in it.  The  SCFIFO is  for custom logic and  is outside of the HPS/ARM/Nios sub-system.  My Quartus is 23.1 Prime Standard Edition. From the "FIFO IP User Guide  for  Quartus® Prime Design Suite: 25.1.1" it looks like I can enable (hard, memory-build in) ECC protection only for Arria 10 devices with M20K memory.  My Cyclone-V has M10K memory (and Auto and MLAB memory) .  It should be possible for me to add a soft-ECC module in the fabric, either inside the SCFIFO wrapper (from MegaWizard), or outside the SCFIFO wrapper.
Has anyone done (or seen in Altera's Github)  such a soft-ECC module ( for example using a Hamming SEC-DED (24,16) code or similar) ?
  • KennyT_altera's avatar
    KennyT_altera
    This seems to be duplicated case, i shall close one of it. https://community.altera.com/discussions/ip-and-transceiver/cyclone-v-scfifo-with-m10kmlab-memory---adding-ecc/351423
