ShivaKi's avatar
ShivaKi
1 year ago
Cyclone V 5CEBA7F27C8N_Design Security Volatile Key Register
In Cyclone V 5CEBA7F27C8N, If the Design Security Volatile Key is used then VCCBAT pin should be connected to a non-volatile battery power source in the range of 1.2V to 3.0V.
Could you please explain -
What is 'Design Security Volatile Key' means? What is the purpose of this feature? Is it recommended to implement this feature?
  • ShivaKi's avatar
    ShivaKi
    Could you please explain, how to implement this feature? or provide application note (if any) regarding how to implement/program this Design Security Volatile Key feature.
  • Jeet14's avatar
    Jeet14
    The design security features in Intel® 40-, 28- and 20-nm FPGAs to used protect your designs against unauthorized copying, reverse engineering, and tampering of your configuration files.
    The usability depend on the security features required and its optional to use.
    You can refer the AN556: Using the Design Security Features in Intel FPGAs.
    https://cdrdv2-public.intel.com/667084/an556-683269-667084.pdf
    Tiwari
  • Jeet14's avatar
    Jeet14
    Please let me know if you have any questions on this?
    Tiwari
  • Jeet14's avatar
    Jeet14
    Tiwari
