Annu's avatar
Annu
1 month ago
Cyclone 10 LP True DPRAM IP
In Cyclone 10 LP device, TRUE DPRAM IP with single clock is not writing on the odd addresses why is it so
    • Annu's avatar
      Annu
      My RAM is accessed by a Processor where processor is trying to write byte by byte But My RAM is word based. If we try writing byte by byte, does it corrupts the RAM
      • ShengN_altera's avatar
        ShengN_altera
        Yes, a word-based RAM expects aligned word writes, not arbitrary byte writes — unless byte enable is properly handled. You have to properly use the byte enable like for example (2'b11 for 16 bits)
        Take an example:
        Assume:
        • RAM width = 16-bit (2 bytes)
        • Addressing = word-based
        Address mapping:
        Processor addrRAM addrByte lane
        0word 0low byte
        1word 0high byte
        2word 1low byte
        3word 1high byte
        If your design:
        • Always writes full word
        • OR only enables byteena[0] (
          If byte enable is missing or wrong)
        Then:
        AddressResult
        Even (0,2,...)writes lower byte
        Odd (1,3,...)upper byte ignored
        You may check the waveform for byteenable from this doc https://cdrdv2-public.intel.com/654378/ug_ram.pdf (page 39)
  • kmalaww's avatar
    kmalaww
    I’ve seen similar issues in my own projects as well. I faced something like this while working ong Grade Calculator for Students. In my case, it was related to configuration and input mapping, so that may be worth checking.
  • kmalaww's avatar
    kmalaww
    I’ve seen a similar issue before. I’m also facing something similar while working on Secrets Behind the Destiny Matrix. In most cases, it’s related to configuration, address mapping, or input settings. It may be worth checking those areas first.
