15 years agoCounting the position of ones in a binary vector
I want to design a combinatorial circuit for an fpga which will count the position of ones in a 16 bit vector. eg1 if vector is 16'b0000_0000_0011_0101 then output should be 64'h0000_0000_0000_5...
15 years ago --- Quote Start --- I didn't yet proceed to Quartus 10. I compiled under V9.0 with VHDL 1993 settings and got the below error with your recent code. I was under the assumption, that constant slice ranges are required, no idea which other setting may be different. But the point isn't very important. --- Quote End --- This is a "bug" thats been around a while, and have mentioned on our internal wiki. Apparently only Quartus has had a problem with it, no concerns with ISE or Modelsim. Maybe they finally fixed it with Q10!
