14 years agoClock problem
Hi All, I am trying to reduce the clock frequency from 25 MHZ to 12.5 MHZ using VHDL. I also intend to implement this in hardware, however I am having a lot of difficulty with my c...
14 years agoI found this piece of code which divides CLKIN to a fixed value.
Simply change the div := 2000000 assignment and renge to the value you need.entity divider is
port (CLKIN : in std_logic;
CLKOUT : out std_logic );
end entity divider;
architecture divider_a of divider is
subtype small_int is natural range 0 to 2000000;
begin
update: process(CLKIN) is
variable div : small_int := 0;
variable status : bit;
begin
if rising_edge(CLKIN) then
if div = 0 then
div := 2000000;
if status='0' then
CLKOUT <= '1';
else
CLKOUT <= '0';
end if;
status := not status;
else
div := div - 1;
end if;
end if;
end process;
end architecture divider_a;
Note: this was one of the very first things I made with VHDL. Looking at it now I see some points which could have been implemented far better.:oops: Anyway it worked and you can trust using it.
