Agilex 7 DDR4 Reset and ADDR/CMD Clock PCB Implementation Documentation Discrepancy
1. The Agliex 7 F Series EMIF User Guide page 191 Figure 145 of section 6.5.6.3 shows RESET line to DRAM pulled up to VDD with 4.7k ohm resistor and this was implemented on Agilex 7 F series evaluation board
DDR4 memory vendor datasheet (thisis publicly available one for the MT40A2G8VA used on above linked eval board) states RESET must be low while power rails ramp up as pictured below which implies it should be instead pulled down to ground.
Can Altera explain why they recommend pullup which seems to be opposite of what memory vendor specifies?
From above public Micron datasheet
2. Figure 143 in section 6.5.6.1 of Agilex 7 EMIF User Guide shows ADDR/CMD clock terminated to VDD through R and C network.
Altera F Tile eval board has ADDR/CMD clock terminated to GND through R and C network. Can Altera explain why the eval board implementation for this signal termination does not match the EMIF user guide figure 143 recommendation?
From Eval board
Thanks!
Hi Steve9 ,
ASIC or ASSP can drive low at power up sequence, but FPGA needs configuration to download the programming file and during configuration time, pin is flowed and pull up on the board. This is nature of the FPGA pins.
But after configuration is done FPGA will assert low during initialization. So it goes like High -> Low -> High
So the FPGA still can drive the pin low or high regardless the termination scheme.
Adzim
