ETang2's avatar
ETang2
1 month ago
DE10-Lite and sdram controller ip
Hello i have de10-lite and in the past i used sdram-controller ip in platform designer to connect the onboard ram to the nios processor. Now (25.1) it seems that this sdram controller is no more supported and I find nothing to replace it. The ddram controllers seems to be more complicated and I can’t figure out how to use their in this case. Someone coud help me ?
  • ETang2's avatar
    ETang2
    Hi Adzim, i will take a look to this but if somenone could share a simple project including sdram and niosV for DE10-Lite it could be helpfull ....
    Eric
      • ETang2's avatar
        ETang2
        Hi and thanks but ths example design use nios2-gen2 which is deprecated. When i try to replace it with NiosV/m i have errors at the compilation :
        Warning (18236): Number of processors has not been specified which may cause overloading on shared machines.  Set the global assignment NUM_PARALLEL_PROCESSORS in your QSF to an appropriate value for best performance.
        Warning (12251): DE10_LITE_Qsys.intel_niosv_m_0: Properties (associatedClock) have been set on interface reset - in composed mode these are ignored
        Warning (12251): DE10_LITE_Qsys.intel_niosv_m_0: Properties (associatedClock,associatedReset) have been set on interface instruction_manager - in composed mode these are ignored
        Warning (12251): DE10_LITE_Qsys.intel_niosv_m_0: Properties (associatedClock,associatedReset) have been set on interface data_manager - in composed mode these are ignored
        Warning (12090): Entity "altera_std_synchronizer" obtained from "db/ip/de10_lite_qsys/submodules/altera_std_synchronizer.v" instead of from Quartus Prime megafunction library
        Warning (12090): Entity "altera_std_synchronizer_bundle" obtained from "db/ip/de10_lite_qsys/submodules/altera_std_synchronizer_bundle.v" instead of from Quartus Prime megafunction library
        Warning (10037): Verilog HDL or VHDL warning at de10_lite_qsys_sdram.v(318): conditional expression evaluates to a constant
        Warning (10037): Verilog HDL or VHDL warning at de10_lite_qsys_sdram.v(328): conditional expression evaluates to a constant
        Warning (10037): Verilog HDL or VHDL warning at de10_lite_qsys_sdram.v(338): conditional expression evaluates to a constant
        Warning (10037): Verilog HDL or VHDL warning at de10_lite_qsys_sdram.v(682): conditional expression evaluates to a constant
        Warning (12125): Using design file de10_lite_sdram_nios_test.v, which is not specified as a design file for the current project, but contains definitions for 1 design units and 1 entities in project
        Info (12023): Found entity 1: DE10_LITE_SDRAM_Nios_Test
        Warning (10034): Output port "LEDR" at de10_lite_sdram_nios_test.v(49) has no driver
        Warning (10034): Output port "HEX0" at de10_lite_sdram_nios_test.v(52) has no driver
        Warning (10034): Output port "HEX1" at de10_lite_sdram_nios_test.v(53) has no driver
        Warning (10034): Output port "HEX2" at de10_lite_sdram_nios_test.v(54) has no driver
        Warning (10034): Output port "HEX3" at de10_lite_sdram_nios_test.v(55) has no driver
        Warning (10034): Output port "HEX4" at de10_lite_sdram_nios_test.v(56) has no driver
        Warning (10034): Output port "HEX5" at de10_lite_sdram_nios_test.v(57) has no driver
        Warning (10034): Output port "VGA_R" at de10_lite_sdram_nios_test.v(75) has no driver
        Warning (10034): Output port "VGA_G" at de10_lite_sdram_nios_test.v(76) has no driver
        Warning (10034): Output port "VGA_B" at de10_lite_sdram_nios_test.v(77) has no driver
        Warning (10034): Output port "VGA_HS" at de10_lite_sdram_nios_test.v(73) has no driver
        Warning (10034): Output port "VGA_VS" at de10_lite_sdram_nios_test.v(74) has no driver
        Warning (10034): Output port "CLK_I2C_SCL" at de10_lite_sdram_nios_test.v(80) has no driver
        Warning (10034): Output port "GSENSOR_SCLK" at de10_lite_sdram_nios_test.v(84) has no driver
        Warning (10034): Output port "GSENSOR_CS_N" at de10_lite_sdram_nios_test.v(88) has no driver
        Error (10835): SystemVerilog error at riscv.pkg.sv(149): no support for unions
        Error (10835): SystemVerilog error at riscv.pkg.sv(333): no support for unions
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1163): encoded value for element "MXL32" has width 32, which does not match the width of the enumeration's base type (2)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1164): encoded value for element "MXL64" has width 32, which does not match the width of the enumeration's base type (2)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1165): encoded value for element "MXL128" has width 32, which does not match the width of the enumeration's base type (2)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1167): encoded value for element "MXL_RESERVED" has width 32, which does not match the width of the enumeration's base type (2)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1233): encoded value for element "INSTRUCTION_MISALIGNED" has width 32, which does not match the width of the enumeration's base type (5)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1234): encoded value for element "INSTRUCTION_ACCESS_FAULT" has width 32, which does not match the width of the enumeration's base type (5)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1235): encoded value for element "ILLEGAL_INSTRUCTION" has width 32, which does not match the width of the enumeration's base type (5)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1236): encoded value for element "BREAKPOINT" has width 32, which does not match the width of the enumeration's base type (5)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1237): encoded value for element "LOAD_ADDRESS_MISALIGNED" has width 32, which does not match the width of the enumeration's base type (5)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1238): encoded value for element "LOAD_ACCESS_FAULT" has width 32, which does not match the width of the enumeration's base type (5)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1239): encoded value for element "STORE_AMO_ADDRESS_MISALIGNED" has width 32, which does not match the width of the enumeration's base type (5)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1240): encoded value for element "STORE_AMO_ACCESS_FAULT" has width 32, which does not match the width of the enumeration's base type (5)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1241): encoded value for element "USER_ECALL" has width 32, which does not match the width of the enumeration's base type (5)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1242): encoded value for element "SUPERVISOR_ECALL" has width 32, which does not match the width of the enumeration's base type (5)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1243): encoded value for element "MACHINE_ECALL" has width 32, which does not match the width of the enumeration's base type (5)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1244): encoded value for element "INSTRUCTION_PAGE_FAULT" has width 32, which does not match the width of the enumeration's base type (5)
        Error (10355): SystemVerilog Enumeration Type Declaration error at riscv.pkg.sv(1245): encoded value for element "LOAD_PAGE_FAULT" has width 32, which does not match the width of the enumeration's base type (5)
        Error (12152): Can't elaborate user hierarchy "DE10_LITE_Qsys:u0|DE10_LITE_Qsys_intel_niosv_m_0:intel_niosv_m_0|DE10_LITE_Qsys_intel_niosv_m_0_hart:hart"
        Error: Quartus Prime Analysis & Synthesis was unsuccessful. 20 errors, 26 warnings
        Error: Peak virtual memory: 4778 megabytes
        Error: Processing ended: Sat Dec 13 10:39:59 2025
        Error: Elapsed time: 00:01:55
        Error: Total CPU time (on all processors): 00:02:45
        Error (293001): Quartus Prime Full Compilation was unsuccessful. 22 errors, 26 warnings
  • AdzimZM_Altera's avatar
    AdzimZM_Altera
    Hi Eric,
    I think you should monitor the timing analysis and check for any timing violation.
    If any, you should resolve that first. Can also check the clock frequency reported in the Timing report.
    Adzim
  • ETang2's avatar
    ETang2
    Hi AdzimZM_Altera​ and thanks for the solution that seems to work. I used "System and SDRAM Clocks for DE-series Boards" to generate the 100MHz SDRAM clock and all seems fine. The system compile and i can program the card. My system is simple : NIOS V, JTAG_UART and SDRAM controller but when i generate bsp and try to run a test hello_world there is a problem to access memory ....
    Eric
    • SimonT's avatar
      SimonT
      I had the same problem as well. You have to add SDC constraints.
      You can take the constraints from the Eval Kit sources ./Demonstrations/SDRAM_Nios_Test/DE10_LITE_SDRAM_Nios_Test.sdc
  • SimonT's avatar
    SimonT
    I had the same Issue. For me the Eval Kit was quite useless without that IP core. I found the following temporary "solution" in https://community.altera.com/discussions/ip-and-transceiver/replacement-for-sdram-controller-after-v16-1/52218
    Copy the IP core from an Old Quartus ( I think the last version where this core was supported is 18.1) version to the new Quartus version. /ip/altera/sopc_builder_ip/altera_avalon_new_sdram_controller
    Additionally you need to modify the ip/altera/altera_component.ipx file. You have to add a few additional lines to that file.
    </plugin>
     <component
       name="altera_avalon_new_sdram_controller"
       file="sopc_builder_ip/altera_avalon_new_sdram_controller/altera_avalon_new_sdram_controller_hw.tcl"
       displayName="SDRAM Controller Intel FPGA IP"
       version="20.1"
       description=""
       tags="AUTHORSHIP=Intel Corporation /// INTERNAL_COMPONENT=false"
       categories="Memory Interfaces and Controllers/SDRAM"
       factory="TclModuleFactory">
      <tag2 key="COMPONENT_EDITABLE" value="false" />
      <tag2 key="COMPONENT_HIDE_FROM_QUARTUS" value="true" />
      <tag2 key="COMPONENT_HIDE_FROM_SOPC" value="true" />
      <tag2 key="ELABORATION_CALLBACK" value="elaborate" />
      <tag2 key="INSTANTIATE_IN_SYSTEM_MODULE" value="true" />
      <tag2 key="SUPPORTED_FILE_SETS" value="QUARTUS_SYNTH,SIM_VERILOG,SIM_VHDL" />
      <tag2 key="TCL_PACKAGE_VERSION" value="12.0" />
      <tag2 key="VALIDATION_CALLBACK" value="validate" />
      <documentUrl
         displayName="User Guide"
         type="OTHER"
         url="https://documentation.altera.com/#/link/sfo1400787952932/iga1401314928585" />
      <documentUrl
         displayName="Release Notes"
         type="OTHER"
         url="https://documentation.altera.com/#/link/hco1421698042087/hco1421697689300" />
     </component>
     <plugin
       name="altera_avalon_new_sdram_controller.qprs"
       file="sopc_builder_ip/altera_avalon_new_sdram_controller/altera_avalon_new_sdram_controller.qprs"
       displayName="altera_avalon_new_sdram_controller.qprs"
       version="0.0"
       description=""
       tags=""
       categories=""
       type="com.altera.sopcmodel.util.IElementPresetList"
       subtype=""
       factory="PresetFactory">
      <tag2 key="PRESET_TYPE" value="altera_avalon_new_sdram_controller" />
     </plugin>
    These entries are taken from the old altera_component.ipx
    This worked for me in Quartus 23.1 Lite
    AdzimZM_Altera
    Hello ETang2,
    We're no longer supporting SDRAM Controller IP in current Quartus Standard version.
    If you want to use the SDRAM in 25.1, you can try to manually add the verilog code to your project as a custom module.
    Adzim
