MAX® 10 FPGA New Packages: Up to 59% Higher I/O Density vs. Competitors
Altera has begun production shipments of its new MAX® 10 FPGA package options, featuring Variable Pitch Ball Grid Array (VPBGA) technology. These new package options bring big benefits to designers working in space-constrained and I/O-intensive applications.
With these packages, engineers can access 485 I/Os in 19 x 19 mm2, compared to the traditional 27 x 27 mm2, a 50% reduction in package size. Factoring in additional components required by competitors’ FPGAs (configuration flash or power supplies), customers can realize additional board space and cost savings by using these new Altera devices (Figure 1).
Figure 1. A comparison of I/O count available in 19 x 19 mm2 packages from various FPGA vendors, along with power supply and configuration flash requirements. *
New VPBGA Package Customer Benefits:
- High I/O density in a small form factor (2X I/Os per mm2), with up to 485 I/Os
- Compatibility with low-cost board designs (no High-Density Interconnect required)
- Cost-effective integration with standard low-cost PCB manufacturing and reduced layer-count PCBs
- Versions of the VBGA packages powered by a single power supply reduce the need for additional power supply devices, saving BOM cost and board space
Why This Matters?
In modern electronics, from consumer products to data centers, there’s a constant push to fit more functionality into smaller physical spaces, reduce power consumption, and weight. Designers are often faced with a tradeoff between board real estate and I/O count, especially in edge computing, industrial automation, portable medical devices, and automotive systems.
Why MAX 10 FPGAs?
Altera has been using variable-pitch semiconductor packaging technology in several of its high-end families and has now applied it to the popular MAX 10 FPGA family. The MAX 10 family integrates multiple system functions into a single non-volatile device:
- Up to 50K logic elements, on-chip dual-configuration Flash, user flash, embedded ADCs, AI-capable DSP blocks, on-chip RAM, and support for Nios® V 32-bit RISC-V-based soft IP processors.
These features offer numerous customer benefits, including instant-on, dual images with failover, and built-in AES security, making them ideal for compact, low-power, and reliable designs across various applications. Other key features and benefits include:
MAX 10 FPGA Feature |
Benefit |
High I/O Density |
Ideal for applications needing high amounts of GPIO, LVDS, and external memory interfaces |
Compact Form Factor |
Enables dense layouts for handheld or space-constrained systems |
Low Power Operation |
Maintains MAX 10’s hallmark of power efficiency |
DSP blocks |
Resources to efficiently implement mathematical expressions or AI inference algorithms |
Embedded Flash |
Supports instant-on functionality without an external boot memory device, as well as user flash space |
Integrated ADC |
Allows for analog monitoring and control directly on the FPGA |
Key Applications:
Key Applications |
Why MAX 10? |
Use Case Examples |
Industrial Control |
Combines analog-to-digital conversion (ADC), digital logic, and memory in one device.
Automotive Systems
Offers high-speed I/O, deterministic performance, and a compact footprint suitable for harsh environments.
Medical Devices
Built-in flash allows instant-on behavior and reduced board complexity—key for portable or battery-powered devices. |
IoT Gateways |
Integrates flexible I/O and embedded processing to handle multiple protocols at the edge. |
Server Platform Management
Provides secure, low-latency management and monitoring with instant-on capabilities for critical server functions. |
Next Steps:
As demand for compact, flexible, and cost-effective programmable logic continues to grow, these new devices offer engineers the tools they need to push the boundaries of embedded system design. If your next project demands small size, fast time-to-market, and a high number of I/Os, the new MAX 10 VPBGA options offer the FPGA industry’s highest I/O in a 19 x 19 mm2 package and deserve consideration.
Collateral & Support Resources:
With ample supply and manufacturing support until at least 2040, get started in designing with these new package options. Production devices are available to order via Altera-authorized distributors.
Quartus® Prime software:
- Lite Edition (free, no-cost license), version 24.1 (or later) – Download
- Standard Edition (paid license is required), version 24.1 (or later) – Download
Authorized Distributors:
- Worldwide list: Contact Us
Technical documentation:
- Documentation (datasheets, product table, design guides & user guides, pinout files, schematic symbol, and package-related files)
Other related resources:
* Sources: Based on publicly available FPGA vendor product tables as of July 16, 2025
